FIT To SCreen 12 years 9 months ago #4241
  • jorisk
  • jorisk's Avatar
Any "UP" on this? I also want to fit a PDF document to the width and height, even if it doesn't respect the ratio, but I cannot find a way to do it in the 2.9.0 version. I also tried to act on PDFViewVert, but it doesn't work...
FIT To SCreen 12 years 9 months ago #4242
  • jorisk
  • jorisk's Avatar
I tried to fit the width with this in PDFReader.onSizeChanged():
m_view.vSetScale(0.635f, 0, 0);
But it works for the width, not for the height, because it simply "zoom" the document...
FIT To SCreen 12 years 9 months ago #4253
FIT To SCreen 12 years 9 months ago #4257
  • jorisk
  • jorisk's Avatar
Unfortunately, it doesn't do the trick for me... It moves the PDF but it doesn't fit it and then the scroll is not good working.
FIT To SCreen 12 years 9 months ago #4298
  • razvar
  • razvar's Avatar
I'm also looking for this, to be able to fit on height, and display the pages as Polaris Office does, allowing to zoom out more on the page. I'm a registered developer (pro version) and I'm using PDFViewVert com.radaee.reader.PDFReader / com.radaee.view.PDFView for rendering. It will be really nice and more user friendly to not just fit the page to screen Width and allow space like double View page does but for a single page.
Please help us out with a quick solution.
Thanks a lot for all your hard work and continuous support.
Last edit: by x7hlydiz5.
FIT To SCreen 12 years 8 months ago #4437
  • patatafrita
  • patatafrita's Avatar
Very same problem here... whatever I do I can change the size of the page but the frame it is shown in always makes it compolsory to scroll to view all the page. any way to just fit all the page and no need to scroll?
