Add Handwriting Annotation 12 years 6 months ago #4932
  • sparklellama
  • sparklellama's Avatar Topic Author
The following code is intended to insert an HWriting annotation into a PDF. The HWriting has been perviously successfully drawn. However, the code only causes the HWriting to vanish. It is not inserted into the PDF. I have used this code pattern successfully for other annotation types (Ink, Rects, Circles, Comments etc), but it does not work for HWriting. Any clues? Thanks if you can help.
// elsewhere mWw is defined as  new HWriting([view width], [view height], 1.0f, 3.0f, 0, 0, 0);
	public void persist(PDFVPage vpage, int x, int y)
		Page page = vpage.GetPage();
		if (page != null)
			Matrix mat = vpage.CreateMatrix();
			Log.v(this.getClass().getName(), String.format("Persisting hWriting at: %d %d", -vpage.GetVX(x), -vpage.GetVY(y)));
			page.ObjsStart(); // Docs suggest that this might be a good idea, but doesn't seem to help
			page.AddAnnotHWriting(mat, mHw,-vpage.GetVX(x), -vpage.GetVY(y)); // TODO: NOT WORKING
			mat.Destroy();
Add Handwriting Annotation 12 years 6 months ago #4935
plz check this:
public void persist(PDFVPage vpage)
	if (page != null)
		page.AddAnnotHWriting(mat, mHw,-vpage.GetVX(m_view.vGetX()), -vpage.GetVY(m_view.vGetY())); // TODO: NOT WORKING
		mat.Destroy();
Add Handwriting Annotation 12 years 6 months ago #4936
  • sparklellama
Thanks so much for the suggestion. Unfortunately this time, it didn't have any effect. Let me know if you have any more ideas… thanks so much.
Add Handwriting Annotation 12 years 6 months ago #4938
i tested it, and fixed some bugs for this method. plz wait.
and try these codes for next version:
Init:
	private HWriting m_writing = null;
	m_writing = new HWriting( getWidth(), getHeight(), 1, 5, 255, 0, 0 );
case onTouchDown:
	m_writing.OnDown(event.getX(), event.getY());
	PDFPos pos = m_view.vGetPos((int)event.getX(), (int)event.getY());
	PDFVPage vpage = m_view.vGetPage(pos.pageno);
case onTouchMove:
	m_writing.OnMove(event.getX(), event.getY());
case onTouchUp:
	m_writing.OnUp(event.getX(), event.getY());
Add to page:
	page.AddAnnotHWriting(mat, m_writing, -vpage.GetVX(m_view.vGetX()), -vpage.GetVY(m_view.vGetY()));
	mat.Destroy();
	m_view.vRender(vpage);
	m_writing.Destroy();
	m_writing = null;
Add Handwriting Annotation 12 years 6 months ago #4943
A new version 2.9.7beta5 has been pubblished..
This contains a fix to HWriting annotation
Add Handwriting Annotation 12 years 6 months ago #4956
  • sparklellama
Thank you for the new beta version of the library. Unfortunately there was no change upon upgrading to the new library. I have updated the code to more closely reflect your example, but no luck. Thanks if you have any more ideas.
create:
		mView = view;
		mAndroidView = aview;
		// width, height, min stroke width, max stroke width, 3x # = RGB col
		mHw = new HWriting(mAndroidView.getWidth(), mAndroidView.getHeight(),
		mBitmap = Bitmap.createBitmap(mAndroidView.getWidth(),
				mAndroidView.getHeight(), Bitmap.Config.ARGB_8888);
draw:
		mBitmap.eraseColor(0);
		int hndl = Global.lockBitmap(mBitmap);
		mHw.OnDraw(hndl);
		Global.unlockBitmap(mBitmap, hndl);
		c.drawBitmap(mBitmap, 0, 0, null);
touchDown:
		mHw.OnDown(x, y);
		PDFPos pos = mView.vGetPos((int)x, (int)y);
		aPage = mView.vGetPage(pos.pageno);
touchMove:
		mHw.OnMove(x, y);
touchUp:
		mHw.OnUp(x, y);
persist to page:
		Page page = aPage.GetPage();
		if (page != null)
			Matrix mat = aPage.CreateMatrix();
							vpage.GetVX(mView.vGetX()),
							-vpage.GetVY(mView.vGetY())));
								// but doesn't seem to help
			page.AddAnnotHWriting(mat, mHw, -vpage.GetVX(mView.vGetX()),
					-vpage.GetVY(mView.vGetY())); // Not working
			mat.Destroy();
			mView.vRender(aPage);
			mHw.Destroy();
			mHw = null;
