How to merge two documents? 12 years 5 months ago #5165
  • douglasmedia
  • douglasmedia's Avatar Topic Author
I want to merge two documents into one single document. Therefore I've developed this method:
    public static boolean mergeDocuments(Document doc1, Document doc2) {
        Document.ImportContext importContext = doc1.ImportStart(doc2);
        if (importContext != null) {
            doc1.ImportPage(importContext, 1, 2);
            importContext.Destroy();
            return true;
        return false;
Unfortunally, the method returns always false, because importContext is null. I have debugged the project and go into the method "ImportStart()". The variable "hand" is 0.
	public ImportContext ImportStart( Document src )
		if( src == null ) return null;
		int hand = importStart( hand_val, src.hand_val );
		if( hand != 0 ) return new ImportContext(this, hand);
		else return null;
Seems like it is a bug in the library. Can anybody help me?
Thank you!
How to merge two documents? 12 years 5 months ago #5172
plz check doc1 has invoked doc1.SetCacheData(...);
and you have actived premium license.
then do like this:
        int pageno = doc1.GetPageCount();
        int cnt = doc2.GetPageCount();
            for( int cur = 0; cur < cnt; cur++ )
                doc1.ImportPage(importContext, cur, pageno);
                pageno++;
            doc1.Save();
            return true;
        return false;
How to merge two documents? 12 years 5 months ago #5317
  • douglasmedia
Thank you for your help. I've tried it with your recommended solution, but importContext is still null. Should it work with the trial licence?
I am using the method like this:
    private PDFReader initReader(String path1, String path2) {
        mReader = new PDFReader(parent, null);
        mDoc1 = new Document();
        int ret1 = mDoc1.Open(path1, null);
        if (!TextUtils.isEmpty(path2)) {
            mDoc2 = new Document();
            mDoc2.Open(path2, null);
            PDFHelper.mergeDocuments(mDoc1, mDoc2);
        if (ret1 == 0) {
            mReader.PDFOpen(mDoc1, false, null);
            return mReader;
        return null;
Best regards,
Robin
How to merge two documents? 12 years 5 months ago #5325
The code should work, make sure that the demo project is activated with the premium license..
try to check with PDFTestAct.concate_pdf
How to merge two documents? 12 years 5 months ago #5365
  • douglasmedia
Thank you! It works! The package for the demo project was wrong...
But how can I merge the documents without saving the result? I just want to merge document 2 in document 1 and display the result, without saving the result on the disc. Is that possible?
Beste regards.
How to merge two documents? 12 years 5 months ago #5380
you'd better managed 2 Document as 1 document by wrapping a new Document class.
