Explanation of Feature List Required 12 years 5 months ago #5229
yes, it should be sufficient..
PDF index handling and modification:
Read or create PDF navigation index..(table of contents)
Document.GetOutlines()
//http://www.androidpdf.mobi/documentation/javadocs/com/radaee/pdf/Document.html#GetOutlines()
Outline.AddChild();
Outline.AddNext();
Outline.RemoveFromDoc()
Outline.SetTitle();
Outline.GetChild();
Outline.GetNext(); ...
//http://www.androidpdf.mobi/documentation/javadocs/com/radaee/pdf/Document.Outline.html
The following user(s) said Thank You: miguel.garcia
Explanation of Feature List Required 12 years 5 months ago #5243
  • sachin.1.kumar
  • sachin.1.kumar's Avatar Topic Author
The content of the PDF book overflows the screen area after zoom. The user needs to scroll the screen area to read the content.
Normally in any reader the content flows to next page after zoom so that scrolling is not required to read the content.
Is this feature available in any of your license(Standard/Professional/Premium)?
Can I use this feature using the trial version to create a POC(Proof of Concept)?
If yes How it can be used?
Please reply ASAP.
Explanation of Feature List Required 12 years 5 months ago #5244
How can you see the other content without scrolling???
Which readers do that?
I do not think we have this feature
Explanation of Feature List Required 12 years 5 months ago #5249
  • sachin.1.kumar
Ok. Thanks.
Is there any feature available through which we can increase the font size of PDF content without using pinch zoom?
Explanation of Feature List Required 12 years 5 months ago #5252
You can set the zoom by calling m_reader.PDFSetScale(scale);
Explanation of Feature List Required 12 years 5 months ago #5266
  • sachin.1.kumar
Thanks for the reply.
I found m_vPDF.m_pdv.vSetScale(float scale, float fx, float fy) to set the scale, but this is not working.
m_vPDF is an object of ReaderController class and m_pdv is an object of PDFView class declared inside ReaderController.
Please help.
