Exception when importing the library 12 years 4 months ago #5624
  • msaudi
  • msaudi's Avatar Topic Author
When I imported the library to my project I get the error below. I use ORMLite and the stlport_shared exists and included on libs folder. the app works fine without including PDFReader library in my project
03-12 11:51:22.224: E/AndroidRuntime(30512): FATAL EXCEPTION: main
03-12 11:51:22.224: E/AndroidRuntime(30512): Process: com.appsv.readbook, PID: 30512
03-12 11:51:22.224: E/AndroidRuntime(30512): java.lang.UnsatisfiedLinkError: Couldn't load stlport_shared from loader dalvik.system.PathClassLoader[DexPathListzip file "/data/app/com.appsv.readbook-2.apk"],nativeLibraryDirectories=[/data/app-lib/com.appsv.readbook-2, /vendor/lib, /system/lib]: findLibrary returned null
03-12 11:51:22.224: E/AndroidRuntime(30512): at java.lang.Runtime.loadLibrary(Runtime.java:358)
03-12 11:51:22.224: E/AndroidRuntime(30512): at java.lang.System.loadLibrary(System.java:526)
03-12 11:51:22.224: E/AndroidRuntime(30512): at net.sqlcipher.database.SQLiteDatabase.loadLibs(SQLiteDatabase.java:112)
03-12 11:51:22.224: E/AndroidRuntime(30512): at net.sqlcipher.database.SQLiteDatabase.loadLibs(SQLiteDatabase.java:107)
03-12 11:51:22.224: E/AndroidRuntime(30512): at com.appsv.readbook.model.db.DBManager.<init>(DBManager.java:25)
03-12 11:51:22.224: E/AndroidRuntime(30512): at com.appsv.readbook.model.db.DBManager.getInstance(DBManager.java:16)
03-12 11:51:22.224: E/AndroidRuntime(30512): at com.appsv.readbook.model.dao.db.DbAbstractDao.<init>(DbAbstractDao.java:14)
03-12 11:51:22.224: E/AndroidRuntime(30512): at com.appsv.readbook.model.dao.db.UserDataDao.<init>(UserDataDao.java:16)
03-12 11:51:22.224: E/AndroidRuntime(30512): at com.appsv.readbook.model.dao.db.UserDataDao.getInstance(UserDataDao.java:25)
03-12 11:51:22.224: E/AndroidRuntime(30512): at com.appsv.readbook.common.Global.getuserdata(Global.java:52)
03-12 11:51:22.224: E/AndroidRuntime(30512): at com.appsv.readbook.ui.activity.BaseFragmentActivity.onStart(BaseFragmentActivity.java:83)
03-12 11:51:22.224: E/AndroidRuntime(30512): at android.app.Instrumentation.callActivityOnStart(Instrumentation.java:1171)
03-12 11:51:22.224: E/AndroidRuntime(30512): at android.app.Activity.performStart(Activity.java:5241)
03-12 11:51:22.224: E/AndroidRuntime(30512): at android.app.ActivityThread.performLaunchActivity(ActivityThread.java:2168)
03-12 11:51:22.224: E/AndroidRuntime(30512): at android.app.ActivityThread.handleLaunchActivity(ActivityThread.java:2245)
03-12 11:51:22.224: E/AndroidRuntime(30512): at android.app.ActivityThread.access$800(ActivityThread.java:135)
03-12 11:51:22.224: E/AndroidRuntime(30512): at android.app.ActivityThread$H.handleMessage(ActivityThread.java:1196)
03-12 11:51:22.224: E/AndroidRuntime(30512): at android.os.Handler.dispatchMessage(Handler.java:102)
03-12 11:51:22.224: E/AndroidRuntime(30512): at android.os.Looper.loop(Looper.java:136)
03-12 11:51:22.224: E/AndroidRuntime(30512): at android.app.ActivityThread.main(ActivityThread.java:5017)
03-12 11:51:22.224: E/AndroidRuntime(30512): at java.lang.reflect.Method.invokeNative(Native Method)
03-12 11:51:22.224: E/AndroidRuntime(30512): at java.lang.reflect.Method.invoke(Method.java:515)
03-12 11:51:22.224: E/AndroidRuntime(30512): at com.android.internal.os.ZygoteInit$MethodAndArgsCaller.run(ZygoteInit.java:779)
03-12 11:51:22.224: E/AndroidRuntime(30512): at com.android.internal.os.ZygoteInit.main(ZygoteInit.java:595)
03-12 11:51:22.224: E/AndroidRuntime(30512): at dalvik.system.NativeStart.main(Native Method)
Exception when importing the library 12 years 4 months ago #5626
the project must include libs subdir.
some librdpdf.so for different paltform.
Exception when importing the library 12 years 4 months ago #5627
  • msaudi
This is not the problem. I have included the full project of yours including all libraries and its sub folders and it works as long as I don't use any SQLite code that uses sqlcipher. I think this could be the problem. Do you have problems with sqlcipher integration or so ?
Exception when importing the library 12 years 4 months ago #5628
it seems SQLChiper use stl for C++
"stlport_shared"
PDF library just use libc not include any C++ library.
Exception when importing the library 12 years 4 months ago #5631
  • msaudi
So ? what do you think the problem could be ?
Exception when importing the library 12 years 4 months ago #5635
  • msaudi
I found the problem in armeabi-v7a version of the library. If I added this folder, I have this crash. If i removed it and left the other folders armeabi, mips, x86 and the jar file, The app launched and did not crash.
May I know how removing this folder affects my project ? should I include all of them. I'm building Android application which will run in all android supported devices.
