Thumbnail view is not working smoothly 12 years 3 months ago #6080
does you try last beta version?
others: do not set Android:targetSDKVersion in AndroidManifest.xml, it make performance slow down.
Thumbnail view is not working smoothly 11 years 10 months ago #7060
  • bashirisonline
  • bashirisonline's Avatar Topic Author
Hey Guys I am now using last stable version, But facing same problem.
Thumbnail view is not working smoothly 11 years 10 months ago #7268
  • bashirisonline
Hello guys,
Have you looked into the issue??
Thumbnail view is not working smoothly 11 years 10 months ago #7276
are you update java codes?
try demo project, not your project.
Thumbnail view is not working smoothly 11 years 10 months ago #7292
  • bashirisonline
I have already updated library to last stable build (not beta versions). is it fixed in beta version?
Thumbnail view is not working smoothly 11 years 10 months ago #7294
last release is OK, update native library and java source codes.
especially, package com.radaee.view need to be updated.
