Wrong font displayed in document. 12 years 2 months ago #6125
  • LingvistonTheOne
  • LingvistonTheOne's Avatar Topic Author
Hello Radaee team!
We've bought reader license for uor application which must be released in the end of this week. During testing we've found out that there's at least one document where incorrect font is displyed. We need to get this issue fixed very soon. How can we contact with you for support (cause this definitly looks like a bug)?
Wrong font displayed in document. 12 years 2 months ago #6128
This usually happens when the font is not embedded in the pdf, the SDK uses a default font to show the content,
If the font is already embedded, can you send us the pdf to test it..
Wrong font displayed in document. 12 years 2 months ago #6129
  • LingvistonTheOne
Sure, can you give me email?
And by the way maybe I can change the default font for rendering by myself?
Last edit: by chetberry.
Wrong font displayed in document. 12 years 2 months ago #6130
This email address is being protected from spambots. You need JavaScript enabled to view it.
for font check:
www.androidpdf.mobi/forum/Android-develo...-multiple-fonts#2903
put the fonts which used in PDF in assets folder, then import them in Global.Init function by this code:
load_std_font( "rdf013", assets, files );
then:
fontfileListAdd(fonts_path + fontfilename);
setDefaultFont(null, "DroidSans", true);
Wrong font displayed in document. 12 years 2 months ago #6136
  • LingvistonTheOne
I've found out using Adobe Reader that problematic page has not embedded font Palatino-Roman. I've downloaded it from here font.downloadatoz.com/download,55787,pal...-th-for-windows.html (even if I need to pay for it I prefer first to check that it works) and added to assets folder as PR.ttf. And here's the code I added to Global.Init() function:
fontfileListStart();
// esisting code
fontfileListAdd("/system/fonts/DroidSans.ttf");
fontfileListAdd("/system/fonts/Roboto-Regular.ttf");
fontfileListAdd("/system/fonts/DroidSansFallback.ttf");
// added code
fontfileListAdd("/assets/PR.ttf");
fontfileListEnd();
setDefaultFont(null, "Palatino-Roman", true);
But it doesn't help me. Looks like I'm doing something wrong like using wrong font or declaring wrong fontfamily. I've already sent you the problematic page so maybe you can point at the mistake.
Wrong font displayed in document. 12 years 2 months ago #6140
"/assets/PR.ttf" is a wrong path.
you shall: extract PR.ttf to sandbox, and then load it from sandbox.
just do like "rdf013" in assets
