Set cache fails and succeeds randomly 12 years 1 month ago #6448
  • manderin87
  • manderin87's Avatar Topic Author
SetCache is still failing. I need to find out why. I made sure each document is using a different cache file and the document is getting closed when no longer needed.
Does it require the premium code? If so, why, I'm not creating a pdf, just saving a annotation to it. At the same time, setcache does work with the professional license, why should it only work occasionally?
thanks
Last edit: by jstampe.
Set cache fails and succeeds randomly 12 years 1 month ago #6449
professional license is OK.
plz to sure:
--cache file in directory already exists.
--cache file has access right, if on sdcard, you need write extern storage access right.
--you can using java codes to create the file by path, if you not sure you has access write.
Set cache fails and succeeds randomly 12 years 1 month ago #6455
  • manderin87
This is the code I am using to open the pdf and set the cache
mPDF = (PDFReader) rootView.findViewById(R.id.reader_pdf);
mPDFDocument = new Document();
mPDFDocument.Close();
mPDFStream = new PDFFileStream();
if(!mFilePath.isEmpty()) {
mPDFStream.open(mFilePath);
int ret = mPDFDocument.OpenStream(mPDFStream, null);
boolean cache = mPDFDocument.SetCache(Global.tmp_path + "/" + mBook.id() + String.valueOf(mPageNumber) + "temp.dat");
if(Settings.DEBUG && !cache) {
Utilities.displayToast(mApp, "SetCache: failed");
switch( ret ) {
	case -1://need input password
		getActivity().finish();
		break;
	case -2://unknown encryption
		break;
	case -3://damaged or invalid format
		break;
	case -10://access denied or invalid file path
		break;
	case 0://succeeded, and continue
		break;
	default://unknown error
		break;
mPDF.PDFOpen(mPDFDocument, false, this);
Set cache fails and succeeds randomly 12 years 1 month ago #6456
  • manderin87
I think the problem is the cache file... how can I open multiple pdfs with seperate cache files? It seems to open once and then not again. Is there anyway for the document to handle its own cache?
I have no idea if the cache is even being created. The file is not in global temp. Im assuming if the cache cannot be created then setcache would return false. Why would it not be able to be created? I have the external permissions set.
I checked the temp directory and found that the cache is indeed not there on the occasions where setcache succeeded. So if I call setcache again with the same temp filename. Why would it fail?
Would it be possible to see the code for setcache?
Set cache fails and succeeds randomly 11 years 5 months ago #8536
  • clavarreda
  • clavarreda's Avatar
A bit late, but I had a similar problem with an app that I was checking. The first time I opened a document bitmaps were just fine, but when I had closed that document and opened another one the bitmaps didn't work. The problem was that when the user closed the document the developer invoked Global.RemoveTmp(); but that deletes the tmp directory created when initializing the library and that was causing me some headaches
I hope this could help
