Bitmap Text are cropped when rendered 11 years 10 months ago #6628
  • topher.guray
  • topher.guray's Avatar Topic Author
Please check the sample PDF file. It was created using Microsoft Save As PDF option.
The Bitmap Text checkbox was ticked when the document was saved as PDF.
The PDF Viewer ver 2.9.4 cannot render Bitmap Text properly. The Bitmap Text are cropped.
Sample PDF file
Example of fonts - Bitmap Text.pdf
dl.dropboxusercontent.com/u/121053329/Ex...%20Bitmap%20Text.pdf
Bitmap Text are cropped when rendered by the PDF Viewer ver 2.9.4
dl.dropboxusercontent.com/u/121053329/Bi...xt%20-%20cropped.JPG
Bitmap Text are cropped when rendered 11 years 10 months ago #6631
This issue seems to solved in later versions ...
With the latest version 2.9.11beta9 the text is not cropped..
but The font is not correct, we will check this and get back to you
The following user(s) said Thank You: Prabhanshu
Bitmap Text are cropped when rendered 11 years 10 months ago #6640
Please check the new uploaded version 2.9.10beta10
It should render the font correctly
Bitmap Text are cropped when rendered 11 years 9 months ago #6780
  • topher.guray
"it should render the font correctly",
do you mean the font text's edges are now displayed sharply? (not coarse?)
Bitmap Text are cropped when rendered 11 years 9 months ago #6783
no, all renders OK, you'd better try the last beta.
Bitmap Text are cropped when rendered 11 years 9 months ago #6786
  • topher.guray
Please try to use sample PDF below. You will notice that the text "Tesco Black" is displayed coarsely when the PDF is using a Bitmap Text.
Coarse display
dl.dropboxusercontent.com/u/121053329/Bi...coarse%20display.pdf
Fine display
dl.dropboxusercontent.com/u/121053329/NO...20fine%20display.pdf
Please check. Thanks.
