PDF AES stream 12 years 1 week ago #6649
  • petr.sklenicka
I have a problem with using of a class PDFAESStream. I have an encrypted book and I'm trying to open it. For this purpose I use this code:
PDFAESStream stream = new PDFAESStream();
stream.open(bookPath, "MySecretKeyABCDE".getBytes());
The bookPath variable is an existing path to the book, which is encrypted via AES.
The open() method always returns false. For encryption, I simply used AES/CBC/PKCS5Padding. The open() method still returns false, because the condition
if( m_enc_len % BLOCK_ENC_SIZE != 4 ) // Line from your code
is always true.
Where is the problem?
Thank you in advance for your reply.
PDF AES stream 12 years 1 week ago #6652
PDFAESStream is customer format file.
you shall use PDFAESStream.ImportFromFile() to create a encrypted PDF file.
to create encrypted PDF file codes like:
stream.ImportFromFile( "path-name" );
stream.ExportToFile( "an other path-name" );
stream.close();
to open encrypted PDF file codes like:
stream.open( "path_name", password );
doc.OpenStream( stream, ... );
doc.Close();
stream.close();
PDFAESStream may used in pure java envirment on linux/windows and so on.
PDF AES stream 12 years 1 week ago #6655
  • petr.sklenicka
Ok, thank you for your reply.
I tried your code, but it does not work. A method ImportFromFile returns false. The problem is with this line:
m_file.setLength(0);
m_file is null. I use exactly this code:
stream.ImportFromFile(inputPath);
stream.ExportToFile(outputPath);
stream.close();
The variable inputPath is path of the book and this path exists.
PDF AES stream 12 years 1 week ago #6658
sorry, forgot something.
codes:
stream.open( outputPath, password );
stream.close();
PDF AES stream 12 years 1 week ago #6660
  • petr.sklenicka
This code works. It creates a new file with length 4096 bytes. Is this correct? I thought that it will create a new file - the encrypted PDF document with AES.
PDF AES stream 12 years 1 week ago #6663
there are example in ReaderActivity.java
some codes are commented.
//byte key[] = new byte[16];
//stream.open("/sdcard/ttt.pdf", key);
//stream.ImportFromFile("/sdcard/test.pdf"); //encrypt to /sdcard/ttt.pdf
//stream.ExportToFile("/sdcard/test1.pdf"); //decrypt to /sdcard/test1.pdf
these codes shall tested.
