Lib abilities 11 years 11 months ago #6826
  • Dmitry Kazakov
  • Dmitry Kazakov's Avatar Topic Author
I make some research for my client and want to understand capabilities of the app.
I don't see in the demo app how I can load pdf from sdcard or from the internal memory. Is it possbile? Do you have a code snippet?
I want to show pad as scrollable pages. Does is possible? Do you have app that demonstrates this?
Lib abilities 11 years 11 months ago #6828
load pdf from sdcard or from the internal memory: Yes, it's possible, you need to pass the file path to the open method, check
www.androidpdf.mobi/documentation/javado...ocument.html#OpenMem(byte[], java.lang.String)
code snippet:
m_doc.open("/sdcard/test.pdf", "");
check also the demo project PDFReader.PDFOpen(Document, boolean, PDFReaderListener, PDFViewListener)
show pad as scrollable pages: do not understand what you mean, can you explain?.
Last edit: by marcoP.
Lib abilities 11 years 11 months ago #6830
  • Dmitry Kazakov
Thank you.
I want to understand can I show pdf in others ways. For example I would like to open pdf as scrollable pages as other pdf viewers do this.
Is it possible?
Also I would like to make pdf viewer as fullscreen component.
It seems that app doesn’t support this automatically. Can you tell me which part of code is responsible for this?
Lib abilities 11 years 11 months ago #6831
You can change the view mode, by changing the value of def_view variable in Global.default_config ..give them a try
fullscreen, no direct method to do so, you need to implement it yourself
Lib abilities 11 years 11 months ago #6833
  • Dmitry Kazakov
New values in public static int def_view = 2; does not affect anything.
Does I understand you corrrectly that I need to modify NDK code to draw pdf as a fullscreen view?
Lib abilities 11 years 11 months ago #6835
you need to change the value in Global.default_config..
No, not NDK you need to deal with it as a normal view, to make it as fullscreen you need to hide the action bar..
requestWindowFeature(Window.FEATURE_NO_TITLE);
getWindow().setFlags(WindowManager.LayoutParams.FLAG_FULLSCREEN,
WindowManager.LayoutParams.FLAG_FULLSCREEN);
android:theme="@android:style/Theme.NoTitleBar.Fullscreen"
