How to render(View) pdf file 11 years 9 months ago #7372
  • asliyanage
Can you provide simple example?Demo project contains the large number of files?I need to view pdf file in my app?
How to render(View) pdf file 11 years 9 months ago #7373
please check in the demo project the PDFReader and PDFReaderAct class.
This will help you!
Last edit: by poudel.
How to render(View) pdf file 11 years 9 months ago #7378
  • asliyanage
can you provide a simple code to load pdf file from a given path ?
How to render(View) pdf file 11 years 9 months ago #7380
try to add this in the InitView() void in PDFReaderAct class..
m_doc = new Document();
m_doc.Open( your_pdf_path, your_pdf_password );
m_reader.PDFOpen(m_doc, false, this);
How to render(View) pdf file 11 years 9 months ago #7586
  • asliyanage
How to call this in a fragment as last argument is PDFReader.PDFReaderListener ?.In a activity we can implement this listener.I need to view pdf five in a viewpager which has several fragments.
Below is my fragments code.
package com.sph.pdf;
import java.io.File;
import java.io.InputStream;
import com.radaee.pdf.Document;
import com.radaee.pdf.Global;
import com.radaee.pdf.Page.Annotation;
import com.radaee.reader.PDFReader;
import com.radaee.reader.PDFReader.PDFReaderListener;
import com.radaee.util.PDFThumbView;
import com.radaee.view.PDFVPage;
import android.content.Intent;
import android.content.res.AssetManager;
import android.net.Uri;
import android.os.Bundle;
import android.os.Environment;
import android.support.v4.app.Fragment;
import android.support.v4.view.ViewPager;
import android.util.Log;
import android.view.LayoutInflater;
import android.view.MotionEvent;
import android.view.View;
import android.view.View.OnClickListener;
import android.view.ViewGroup;
import android.view.ViewGroup.LayoutParams;
import android.widget.ImageView;
import android.widget.RelativeLayout;
import android.widget.TextView;
import android.widget.Toast;
public class MyFragment extends Fragment implements PDFReaderListener {
	public static final String EXTRA_MESSAGE = "EXTRA_MESSAGE";
	public static int count = 1;
	static String file;
	TextView txt;
	private PDFThumbView m_thumb = null;
	private Document m_doc = new Document();
	private RelativeLayout m_layout;
	private PDFReader m_reader = null;
	private RelativeLayout mContentView;
	public static final MyFragment newInstance(String message) {
		MyFragment f = new MyFragment();
		Bundle bdl = new Bundle(1);
		bdl.putString(EXTRA_MESSAGE, message);
		f.setArguments(bdl);
		file = message;
		return f;
	public View onCreateView(LayoutInflater inflater, ViewGroup container,
			Bundle savedInstanceState) {
		mContentView = new RelativeLayout(getActivity());
		mContentView.setLayoutParams(new LayoutParams(
				LayoutParams.MATCH_PARENT, LayoutParams.MATCH_PARENT));
		openDoc("/mnt/sdcard/pdf/1.pdf");
		return mContentView;
	public void openDoc(String path) {
		try {
			File sdCard = Environment.getExternalStorageDirectory();
			File imageFolder = new File(sdCard.getAbsolutePath());
			String rootPaperFolder = imageFolder.toString();
			// View v = inflater.inflate(R.layout.pdf_fragment, container,
			// false);
			Global.Init(getActivity());
			m_layout = (RelativeLayout) LayoutInflater.from(getActivity()).inflate(R.layout.reader, null);
			m_reader = (PDFReader) m_layout.findViewById(R.id.view);
			Log.e("m_reader.PDFOpen", ""+m_reader);			m_doc.Close();
			int ret = m_doc.Open(path, null);
			if (ret == 0) {
				// m_doc.SetCache( Global.tmp_path + "/temp.dat" );
		} catch (Exception e) {
			e.printStackTrace();
	public void onDestroyView() {
		super.onDestroyView();
		// Log.d("PDFVIEW", "onDestroyView");
		try {
			if (m_thumb != null) {
				m_thumb.thumbClose();
				m_thumb = null;
			if (m_reader != null)
				m_reader.PDFClose();
			if (m_doc != null)
				m_doc.Close();
			Global.RemoveTmp();
			super.onDestroy();
	public void OnPageModified(int pageno) {
		// TODO Auto-generated method stub
	public void OnPageChanged(int pageno) {
	public void OnAnnotClicked(PDFVPage vpage, Annotation annot) {
	public void OnSelectEnd(String text) {
	public void OnOpenURI(String uri) {
	public void OnOpenJS(String js) {
	public void OnOpenMovie(String path) {
	public void OnOpenSound(int[] paras, String path) {
	public void OnOpenAttachment(String path) {
	public void OnOpen3D(String path) {
it gives me 10 for ret value.But if i put the same code in activity it gives me 0 for ret varible.
Last edit: by Docrishav.
How to render(View) pdf file 11 years 8 months ago #7695
ret = 10 means access denied or invalid file path.
Please check the path.
