Does Radaee provide encription 11 years 7 months ago #8047
  • asliyanage
I tried with below
byte[] key = "MySecretKeyABCDE".getBytes()
stream.open(path,key);
Then it gives me below error .
The method open(AssetManager, String) in the type PDFAssetStream is not applicable for the arguments (String, byte[])
How to get the AssetManager value to this method ?
Last edit: by Docrishav.
Does Radaee provide encription 11 years 7 months ago #8071
  • asliyanage
Hi Radaee ,
Please tell me what is the AssetManager and how do i add this to encryption for pdf ?
Does Radaee provide encription 11 years 7 months ago #8073
it is very simple:
//stream from AES
//private PDFAESStream stream = new PDFAESStream();
//stream from AES
//byte[] key = "MySecretKeyABCDE".getBytes();
//stream.open("/sdcard/ttt.pdf", key);
//stream.ImportFromFile("/sdcard/test.pdf");
//stream.ExportToFile("/sdcard/test1.pdf");
//stream.close();
//stream.open("/sdcard/EncryptedCatalog.pdf", key);
//stream.ExportToFile("/sdcard/decrypt.pdf");
Does Radaee provide encription 11 years 7 months ago #8075
  • asliyanage
Hi Radaee,
Can you explain what each of this line doing as i am confusing both open and ImportFromFile doing same thing?
below are the my imagination for each line.please explain
byte[] key = "MySecretKeyABCDE".getBytes(); = get byte array
//stream.open("/sdcard/ttt.pdf", key); = get the pdf file from sdcard
//stream.ImportFromFile("/sdcard/test.pdf"); = open pdf file from sdcard
//stream.ExportToFile("/sdcard/test1.pdf"); = save the encrypted pdf file
//stream.close(); = close the pdf file
Does Radaee provide encription 11 years 7 months ago #8077
byte[] key = "MySecretKeyABCDE".getBytes(); // get byte array as key to encryption
stream.open("/sdcard/ttt.pdf", key); //create PDF file as encrypted PDF file.
stream.ImportFromFile("/sdcard/test.pdf"); //load contents, and then encrypt it to ttt.pdf
stream.ExportToFile("/sdcard/test1.pdf"); //decrypt contents, and then export ro test1.pdf, so test1.pdf shall same to test.pdf, this step just for test purpose.
stream.close(); //flush ttt.pdf and close file.
//now open the encrypted PDF file:
m_doc.OpenStream(stream);
//to do...
m_doc.Close();
Does Radaee provide encription 11 years 7 months ago #8080
  • asliyanage
1)byte[] key = "MySecretKeyABCDE".getBytes(); // get byte array as key to encryption
2)stream.open("/sdcard/ttt.pdf", key); //create PDF file as encrypted PDF file.
3)stream.ImportFromFile("/sdcard/test.pdf"); //load contents, and then encrypt it to ttt.pdf
4)stream.ExportToFile("/sdcard/test1.pdf"); //decrypt contents, and then export ro test1.pdf, so test1.pdf shall same to test.pdf, this step just for test purpose.
5)stream.close(); //flush ttt.pdf and close file
6)stream.open("/sdcard/ttt.pdf", key);
7)m_doc.OpenStream(stream);
8)m_doc.Close();
I tried with above then it gives me below error in 7th line.what is the Sting do i need to add here?
The method OpenStream(Document.PDFStream, String) in the type Document is not applicable for the arguments (PDFAESStream)
