how to overide vOnZoomEnd() method 11 years 9 months ago #7384
  • asliyanage
I need to overide the vOnZoomEnd() and increase the zoom facility.Can i have any example for this ?
how to overide vOnZoomEnd() method 11 years 9 months ago #7389
First: to override vOnZoomEnd() you need to subclass PDFView
Second: vOnZoomEnd() is called after the zoom operation is finished.
Third: if you mean by increase zoom facility, increasing zoom max value, then you need to change the value of Global.zoomLevel in Global.default_config()
how to overide vOnZoomEnd() method 11 years 9 months ago #7391
  • asliyanage
can you please provide an example ?
how to overide vOnZoomEnd() method 11 years 9 months ago #7392
try to increase (max value is 5) the zoomLevel parameter in default_config() void in Global class..
Last edit: by poudel.
how to overide vOnZoomEnd() method 11 years 9 months ago #7393
  • asliyanage
when the page is zoom in its maximum, if i double click, i need it to zoom out.how to do this?
how to overide vOnZoomEnd() method 11 years 9 months ago #7395
  • asliyanage
maximum vbalue is no 5.I change the zoomLevel value to 10 and its working fine.
