Hyperlink 11 years 9 months ago #7516
I did not get what you mean by "For the same we are not able to find co-ordinates."
If you know the word to search, you can use the above solution.
Hyperlink 11 years 9 months ago #7565
  • abhishekjaju
  • abhishekjaju's Avatar Topic Author
Hello I am using method currentPage.ObjsGetCharRect(index, vals);
This method having void return type and we need to pass float co-ordinates of the particular text position.
So What parameters can I pass to currentPage.AddAnnotURI(, "Audience"), this method.
For getting the co-ordinates of the character but what is the vals and index parameter.
How can I get these parameters?
Last edit: by Nygashi.
