Fit PDF to Screen in Landscape mode
11 years 8 months ago
#7758
abhishekjaju
Senior Member
Thank you received: 1
I tried all the things but PDF is still in vertical mode if do this.
How to change the orientation on PDF to landscape or horizontal.
Where can I change the resolution and fix the same as I need to run this on one device only with 1024*768.
#7785
Davide
User is blocked
Thank you received: 65
try to modify as below and change def_view = 0; in default_config() void of Global class.
Need Real Page Turn Effect For My Views
