How to get hyperlink path in a pdf for Android? 11 years 8 months ago #7740
  • Botao.Lin
  • Botao.Lin's Avatar Topic Author
I downloaded PDFViewer3.1.zip and open the pdf file. Then click the link and click go.
Result is the same.
Please download the pdf file from below path:
drive.google.com/file/d/0B_XpDRBTcIdKSW9...ZGc/view?usp=sharing
How to get hyperlink path in a pdf for Android? 11 years 8 months ago #7741
if you want to open the link check this: www.androidpdf.mobi/forum/Android-develo...ze-openning-url#6922
If it doesn't work please send us a correct path to download your pdf.
How to get hyperlink path in a pdf for Android? 11 years 8 months ago #7745
  • Botao.Lin
Hi, Davide
Please download the pdf file from drive.google.com/file/d/0B_XpDRBTcIdKSW9...ZGc/view?usp=sharing
I tried 3.1 version.
It still can not open the link.
How to get hyperlink path in a pdf for Android? 11 years 8 months ago #7754
how have you generated the link annotation?
Because i tested it even with the Adobe Reader for tablet and it doesn't work too..
How to get hyperlink path in a pdf for Android? 11 years 8 months ago #7763
  • Botao.Lin
Hi Davide
The link is made in a word file.
I also tried Adobe Reader. It also can not open the link.
So the link annotation must be generated by a pdf editor, right?
How to get hyperlink path in a pdf for Android? 11 years 8 months ago #7766
you have to make the link based on the pdf standard rules.
A pdf editor should generate it properly.
Last edit: by poudel.
