Bitmap annotation not added in PDF. 11 years 7 months ago #7966
yes, only exists at last beta or later.
Bitmap annotation not added in PDF. 11 years 7 months ago #7971
  • moontech
  • moontech's Avatar Topic Author
We can't found above methods.
And we need code for addBitmap annotation in PDF using Bitmap object.
So send actual code which work for Bitmap annotation.
Note:
In our application we used three types annotation.
1 Text
2 ink
3 Bitmap
above two working well but bitmap annotation not added in PDF.
Some time annotation added with blank bitmap.
means bitmap not displaying on PDF but rectangle of bitmap displaying.
Bitmap annotation not added in PDF. 11 years 7 months ago #7972
here is piece codes in PDFReader:
PDFPos pos = m_view.vGetPos(touch_x1, touch_y1);
PDFVPage vpage = m_view.vGetPage(pos.pageno);
Page page = vpage.GetPage();
if( page != null )
Matrix mat = vpage.CreateInvertMatrix(m_view.vGetX(), m_view.vGetY());
float rect[] = new float[4];
rect[0] = touch_x1;
rect[1] = touch_y1;
rect[2] = touch_x2;
rect[3] = touch_y2;
mat.TransformRect(rect);
page.AddAnnotBitmap(m_icon, true, rect);
mat.Destroy();
m_view.vRenderSync(vpage);
where touch_x1, touch_y1, touch_x2, touch_y2 is in screen x,y.
touch_x2 > touch x1 and touch_y2 > touch_y1
Bitmap annotation not added in PDF. 11 years 7 months ago #7974
  • moontech
We tried above code but still same issue.
We are using code as below.
m_doc.SetCache(Global.tmp_path + "/temp.dat");
int c_page = Constant.currentpage;
pa = m_doc.GetPage(c_page);
pa.ObjsStart();
PDFVPage vpage = m_rPDF.m_view.vGetPage(c_page);
float[] rect = { 200, 200, (200 + bitmap.getWidth()),
(200 + bitmap.getHeight()) };
pa.AddAnnotBitmap(bitmap, true, rect);
float m_ratio = ((float) m_doc.GetPageHeight(c_page))
/ ((float) m_doc.GetPageWidth(c_page));
Matrix mat = new Matrix(m_ratio, -m_ratio, 0,
m_doc.GetPageHeight(c_page) * m_ratio);
pa.RenderToBmp(bitmap, mat);
m_rPDF.m_view.vRenderSync(vpage);
pa.Close();
mat.Destroy();
bitmap.recycle();
Please let us know what modification it needs.
Bitmap annotation not added in PDF. 11 years 7 months ago #7975
m_doc.SetCache(Global.tmp_path + "/temp.dat"); can't invoke multi-times.
only once m_doc.SetCache can be invoked, for each Document.
Bitmap annotation not added in PDF. 11 years 7 months ago #7976
  • moontech
Now invoking this only once after this
m_doc.Open(val, null);
Still same problem..
