handle zoomlevel in landscap mode 11 years 7 months ago #8152
PDFReader class not fit large zoom level.
there are no better ideas, except set lower zoomlevel.
like this:
if( w > h ) Global.zoomLevel = 4;
else Global.zoomLevel = 6;
another way, is using PDFLayoutView, just set start Activity to PDFLayoutAct in AndroidManifest.xml
last beta version are mostly finished this class.
handle zoomlevel in landscap mode 11 years 7 months ago #8153
  • asliyanage
actually radaee for some pdfs it gives this error even if i used zoom level 5.
Last edit: by Docrishav.
handle zoomlevel in landscap mode 11 years 7 months ago #8154
yes, some PDF file costs much memories.
plz try PDFLayoutAct for last beta version, this class no need of you to set zoomlevel.
and u can send This email address is being protected from spambots. You need JavaScript enabled to view it. for PDF file.
