Zoom-Problem on 64 bit 11 years 2 months ago #8889
  • apait
  • apait's Avatar Topic Author
done
Zoom-Problem on 64 bit 11 years 2 months ago #8891
Last question, may be I missed the information in the long thread: which rendering mode are you using? Single page? Double page? etc.?
Zoom-Problem on 64 bit 11 years 2 months ago #8892
  • apait
Global.zoomLevel = 5;
Global.render_mode = 1;
We're using a customization of PDFViewDual with our own vLayout() depending on orientation and settings.
Zoom-Problem on 64 bit 11 years 2 months ago #8893
It seems the issue is tight to the emulator when multitouch and 64bit emulation are running.
The same, wrong, behavior is present also running "official" applications like calculator or developer options.
