Reflow with vertical scrolling 6 years 4 weeks ago #15121
Page.ReflowStart declared as:
public float ReflowStart( float width, float scale, boolean enable_images )
	 * @param width input width.
	 * @param scale scale base to 72 DPI, 2.0 means 144 DPI. the reflowed text will displayed in scale
	 * @param enable_images enable reflow images.
	 * @return the height that reflow required.
that mean, reflow function need you input a width value to layout.
Reflow with vertical scrolling 6 years 4 weeks ago #15122
  • ankson
  • ankson's Avatar
If I pass the width of page, scale and enable_image then ReflowStart method returns height ' 0 ' then how we can fix this issue?
Reflow with vertical scrolling 6 years 4 weeks ago #15123
if return 0, then ignore this page.
this mostly because the page has no element can be reflow.
for example: transparency group content will be ignored in reflow mode.
The following user(s) said Thank You: ankson
Reflow with vertical scrolling 6 years 4 weeks ago #15124
  • ankson
  • ankson's Avatar
Which is the suitable class for achieving Text Reflow ---- PDFViewAct or PDFLayout ?
Reflow with vertical scrolling 6 years 4 weeks ago #15125
it is better, to create a new Activity.
derive from PDFLayout, may need to modify other related class, so not recommended.
Reflow with vertical scrolling 6 years 4 weeks ago #15126
  • ankson
  • ankson's Avatar
In which overriden method should i call the ReflowStart() Method ?
