IllegalArgumentException occured when zoom 10 years 2 weeks ago #10854
  • philipp
  • philipp's Avatar
Are there any news on this topic? We're getting the same crash when the system destroys an activity that displays PDFViews. The Activity uses a ViewPager with a corresponding adapter to create views that are holding the PDFView instances. When the system calls onDestroy of the activity, we are doing something like ViewPager.setAdapter(null) for memory purposes. This causes the PDFView to receive an onTouchEvent that causes the crash.
Fatal Exception: java.lang.RuntimeException: Unable to destroy activity {ch.nzz.epaper/de.tdsoftware.applisher.reader.pdf.PDFReaderActivity}: java.lang.IllegalArgumentException: pointerIndex out of range
       at android.app.ActivityThread.performDestroyActivity(ActivityThread.java:3813)
       at android.app.ActivityThread.handleDestroyActivity(ActivityThread.java:3831)
       at android.app.ActivityThread.access$1500(ActivityThread.java:175)
       at android.app.ActivityThread$H.handleMessage(ActivityThread.java:1361)
       at android.os.Handler.dispatchMessage(Handler.java:102)
       at android.os.Looper.loop(Looper.java:146)
       at android.app.ActivityThread.main(ActivityThread.java:5602)
       at java.lang.reflect.Method.invokeNative(Method.java)
       at java.lang.reflect.Method.invoke(Method.java:515)
       at com.android.internal.os.ZygoteInit$MethodAndArgsCaller.run(ZygoteInit.java:1283)
       at com.android.internal.os.ZygoteInit.main(ZygoteInit.java:1099)
       at dalvik.system.NativeStart.main(NativeStart.java)
Caused by java.lang.IllegalArgumentException: pointerIndex out of range
       at android.view.MotionEvent.nativeGetAxisValue(MotionEvent.java)
       at android.view.MotionEvent.getX(MotionEvent.java:2189)
       at com.radaee.view.PDFView.motionZoom(PDFView.java:592)
       at com.radaee.view.PDFView.vTouchEvent(PDFView.java:722)
Are they any hints on this?
IllegalArgumentException occured when zoom 10 years 2 weeks ago #10855
today we have published a new stable version of the library with some fixes regarding the ViewPager.
Have you checked it? Can you reproduce the issue?
www.radaeepdf.com/download/download-andr...ile/60-radaeepdf-3-7
IllegalArgumentException occured when zoom 10 years 2 weeks ago #10863
  • philipp
  • philipp's Avatar
Hi Davide,
thanks for the fast reply.
Can you give a short overview about the changlog entry "- FIX a ViewPager issue " of the latest lib? Does it relate to the described bug?
IllegalArgumentException occured when zoom 10 years 2 weeks ago #10866
this thread started 7 months ago, so till now there have been a lot of changes and improvements to the ViewPager.
The latest fix was related to a strange behaviour when changing the targetSdkVersion, now we have fixed it and other minor bugs.
I suggest you to check it and let us know if it solves your problem..
