Edit text and Note not saving data 10 years 7 months ago #9948
  • gabmor
  • gabmor's Avatar Topic Author
Hi, I have a big problem with Edit text and notes, when I write text inside them the text isn't saved, I'm using the PDFReader class from the 3.6 version and the premium trial license. the other functionalities works fine.
This is the code
public void onDismiss()
		Log.d("Reader","onDismiss");
		if( m_edit_type == 1 )//edit box
			EditText edit = (EditText)m_pEdit.getContentView().findViewById(R.id.annot_text);
			Log.d("Reader","Text Edit "+edit.getText().toString());//always return the wrote text
			m_annot.SetEditText(edit.getText().toString());
			Log.d("Reader", "Annot text "+m_annot.GetEditText());//always return null
			m_view.vRenderSync(m_annot_page);
			if( m_listener != null )
				m_listener.OnPageModified(m_annot_page.GetPageNo());
			PDFEndAnnot();
		if( m_edit_type == 2 )//combo
			if( m_sel_index >= 0 )
				m_annot.SetComboItem(m_sel_index);
			m_sel_index = -1;
			PDFEndAnnot();
		m_edit_type = 0;
AlertDialog.Builder builder = new AlertDialog.Builder(getActivity());
        builder.setPositiveButton("OK", new DialogInterface.OnClickListener() {
            public void onClick(DialogInterface dialog, int which) {
                String str_subj = subj.getText().toString();
                String str_content = content.getText().toString();
                Log.d("Reader","Ok click "+m_annot);
                Log.d("Reader","Dialog text "+str_subj+" "+str_content);//always return correct text
                if(m_annot!=null) {
                    m_annot.SetPopupSubject(str_subj);//not saving
                    m_annot.SetPopupText(str_content);//not saving
                dialog.dismiss();
                m_reader.PDFEndAnnot();
                m_set = false;
        builder.setNegativeButton("Cancel", new DialogInterface.OnClickListener() {
                dialog.dismiss();
                m_set = false;
        builder.setTitle("Note Content");
        builder.setCancelable(false);
        builder.setView(layout);
Edit text and Note not saving data 10 years 7 months ago #9949
can you reproduce the issue with the demo project without editing code?
With all the pdfs?
With all devices?
Edit text and Note not saving data 10 years 7 months ago #9950
  • gabmor
In the demo code works fine
Edit text and Note not saving data 10 years 7 months ago #9951
have you activated the library in your own project?
www.radaeepdf.com/support/knowledge-base...=component&kbartid=1
If yes, it must be something related to your own code.
I suggest you to follow the examples you can find in the demo project.
Look at PDFRederAct and PDFReder classes.
Check if this line returns true:
Edit text and Note not saving data 10 years 7 months ago #9952
  • gabmor
Hi, thanks for response but I already say that I'm using trial license. And in my own code I don't touch that part, and other functionalities works fine like add an edit text or check form checkboxes.
Edit text and Note not saving data 10 years 7 months ago #9953
the line I suggest you returns true?
To test all the functionalities with your own project, you need to give it the same package name of the demo project.
