change the color and size of pencil input 10 years 5 months ago #10168
no, PDFLayoutView it's the same and you can see it even in demo version.
change the color and size of pencil input 10 years 5 months ago #10184
  • ankur123987
actually i have some colors if user select the color in that list so ink color will change accordingly but its does not work i used Global.color for change the color but the color is not reflect at the same time while pickup the color,
i hope my question is clear to you
change the color and size of pencil input 10 years 5 months ago #10233
  • ankur123987
i fixed this issue by modified some library code anyway thanks support team
change the color and size of pencil input 9 years 8 months ago #11431
  • eastxing
  • eastxing's Avatar
Hi ankur123987,
Can you show us how you resolve the problem?
change the color and size of pencil input 9 years 8 months ago #11432
I suggest you to check Global.inkColor and Global.inkWidth
change the color and size of pencil input 9 years 8 months ago #11434
  • ankur123987
There is Global class .please change the parameter of Global.INKColor in that file . please view my profile and contact me for further info
