how to get a sentence surrounding selected text 10 years 4 months ago #10110
  • juslee
  • juslee's Avatar Topic Author
Hi Redaeepdf team,
I want to know how to get a sentence surrounding selected text.
Please let me know.
Thank you.
Last edit: by juslee.
how to get a sentence surrounding selected text 10 years 4 months ago #10115
if u mean get textline, u can check '\r' or '\n' on previous and next.
if u mean sentence with words start and end, it shall check by yourself, like punctuation dot, and other analysis.
how to get a sentence surrounding selected text 10 years 4 months ago #10128
  • juslee
Is Radaee PDF software equipped with a function of extracting the related sentence when I click on the word?
(How to extract a selected word and sentence contained the word, when a word is selected.)
how to get a sentence surrounding selected text 10 years 3 months ago #10138
no sentence wrap coding.
but word wrap is equipped.
we check word like this:
if select char is not Latin char, return single char as word.
else :
seek prevous latin char loop to page start, blank or non-latin char.
seek next latin char loop to page end, blank or non-latin char.
return these 2 position, and set select range.
how to get a sentence surrounding selected text 10 years 3 months ago #10139
  • juslee
if Radaee PDF software is not equipped the function, can the function(extracting sentence contained selected word) can implement using Radaee PDF SDK(android and iOS)?
Thank you.
how to get a sentence surrounding selected text 10 years 3 months ago #10140
i think yes.
u may need using Page.ObjsGetString() to get all texts from page.
and Page.ObjsGetCharIndex() tells u char index clicked.
then analysis sentence by yourself.
