Highlight long files 10 years 4 months ago #10394
what version of the library are you using?
PDFReader or RDPDFReader?
Can you reproduce with the last version here : www.radaeepdf.com/download/download-prev...4-radaeepdf-362beta2
Highlight long files 10 years 4 months ago #10396
  • miguel.garcia
  • miguel.garcia's Avatar Topic Author
HI.
I have tested with the version downloaded from the link and the file attached and the same thing happens.
Highlight long files 10 years 4 months ago #10397
I tested it with your pdf and it works properly.
Can you please tell us the steps to reproduce it?
Can you reproduce the issue with all your devices? Which OS version?
Highlight long files 10 years 4 months ago #10398
  • miguel.garcia
Hi.
I am testing with a Nexus 9 Android version 6.0.1
The steps are:
Open the pdf with the open from sdcard button
It loads and work as expected.
Tap on the "pencil" icon.
Select "compte tenu du nombre".
When the dialog is shown i select "Highlight text" and "Ok".
The text is highlighted without any problem.
But now i go to page 2, by vertical dragging or vertical swapping.
No text is displayed, i cannot see the text in the page.
Moreover when i close the file it does not save the highlight or even it is not shown. It seems like it creates a layer that is all over the file or something like that.
Highlight long files 10 years 4 months ago #10401
let's do this test...please try to delete from PDFSample\ViewLib\src\main\jniLibs all the 64 bit architectures:
- arm64-v8a
- mips64
- x86_64
Run the demo app and let us know if the issue persists.
Highlight long files 10 years 4 months ago #10402
  • miguel.garcia
Hi
I am afraid that the problem still persists after deleting these architectures
