How to move text at pdf? 9 years 10 months ago #10410
  • ankur123987
Hello support team,
I added text at pdf now the text is part of pdf. is it possible to move this added text? can you guide me?
if its not possible would it like to add in future release of library
Last edit: by ankur123987.
How to move text at pdf? 9 years 10 months ago #10411
Are you adding text as annotation or on the page?
If second we don't provide a way to alter page structure and we're not planning to introduce such features.
May you write the code you're adopting to add text?
How to move text at pdf? 9 years 10 months ago #10413
  • ankur123987
I am using following method
i am using following code for write the text
content.Create();//create content, do not forget.
content.GSSave();
Matrix mat = new Matrix( 1, 1, 100, 500 );
content.GSSetMatrix(mat);
mat.Destroy();
Page page = m_doc.GetPage(0);
Document.DocFont dfont = m_doc.NewFontCID("DroidSansFallback", 1 | 8);//bold and embed in horizontal writing
ResFont rfont = page.AddResFont(dfont);
content.TextBegin();
content.TextSetFont(rfont, 20);//set font and size
content.SetFillColor(0xff0000);
content.SetStrokeColor(0x10);
content.TextSetCharSpace(0);
content.TextSetWordSpace(0.3f);
content.TextSetLeading(20);
content.TextSetRenderMode(2);//fill and stroke
content.TextSetHScale(120);//set horizontal scale
content.DrawText("RadaeePDF\rTest!");
content.TextEnd();
content.GSRestore();
//add content to page
page.AddContent(content, true);
content.Destroy();
page.Close();
thanks
can i move with the above method?
How to move text at pdf? 9 years 10 months ago #10414
no with that code you can't move the text because it becomes part of the pdf content.
You can move text adding an annotation using that code: www.radaeepdf.com/support/knowledge-base...component&kbartid=43
How to move text at pdf? 9 years 10 months ago #10415
another idea is:
draw rectangle with same color as background, cover the text.
How to move text at pdf? 9 years 10 months ago #10416
  • ankur123987
i think about edittext annotatiion as alternative but the problem with edittext are following
1 I posted in different thread of edittext the move code is not work with RDPDFreader module.
2 I have requirement to move date and time which are text . so for that i have to disable the click listener of this text how can i do it . so that this edit text does not change .
3 i have another requirement where user enter the text in blank edittext which initially size is wrap of 1 character as user enter the character in edittext its change the size and then this edittext is added the pdf
this is the following url for my queries
www.radaeepdf.com/forum/Android-developm...text-at-pdf?start=12
how can i do that ?
