Annotation are not coming in print document 10 years 3 months ago #10473
As told before, I invite you to check the above pdf file I've annotated using Acrobat Pro and MacOSX Preview.
Both files are rendered without annotations by the Android's printing engine.
If android printing engine doesn't contain a feature like what you can see in Acrobat on Windows or Mac (print only document, document and comment, document and fields, etc.) you couldn't be able to print annotations.
Annotation are not coming in print document 10 years 3 months ago #10474
I've just printed your original document using:
- MacOSX Preview
- Acrobat Pro on MacOSX
- AcrobatReader on Windows 10
All are behaving in the proper way.
I was able to DISABLE annotation printing from Acrobat Pro and Acrobat Reader printing requester.
I suspect you could try two ways:
- the Android printing engine could have a flag to print also annotations and its default seems to be "false"
- you should convert all the annotations in page elements just before printing the document
Annotation are not coming in print document 10 years 3 months ago #10475
Note: we will do some deeper check with other files too.
In the meanwhile, please, follow my suggestions from previous posts.
Annotation are not coming in print document 10 years 3 months ago #10476
  • arcmobile.div
  • arcmobile.div's Avatar Topic Author
It is very urgent for us .Please if possible reply as soon as.
Annotation are not coming in print document 10 years 3 months ago #10483
  • arcmobile.div
Any update on this?
Annotation are not coming in print document 10 years 3 months ago #10484
I was anticipating what you are experiencing is a limit of Android printing engine.
Let's check with the linked file: dl.dropboxusercontent.com/u/338927/radaee/annotation.pdf.
I've just generated it using Acrobat Pro and I attached on it a couple of annotations.
Load it on your device and try printing it. I've just checked it on a Nexus 5 with 6.0.1.
I opened the file using Android PDF Viewer and printed it through a file explorer.
I'm also attaching actual screenshots from Google Android PDF Viewer.
The file is rendered correctly.
The printer driver is omitting annotations.
Last edit: by support.
