Checkbox checked image issue 9 years 8 months ago #11444
  • helpLineBV
  • helpLineBV's Avatar Topic Author
I'm trying to update from version 3.5 to 3.9, but am having some trouble with the checkbox image.
Attached is how it looks like. In 3.5 it looked like a normal checked icon.
How can I change it so that it looks the same again like before?
Thanks in advance!
Checkbox checked image issue 9 years 8 months ago #11448
We have checked with some files that we have and couldn't reproduce your issue. Can you please send us the pdf to test it?
The following user(s) said Thank You: helpLineBV
Checkbox checked image issue 9 years 8 months ago #11451
  • helpLineBV
Attached are the pdf form and a screenshot of our implementation of Radaee with the checkboxes checked.
Checkbox checked image issue 9 years 8 months ago #11452
we have checked your pdf with the demo project of the last version of the library and it works properly.
I suggest you to try your pdf with the demo project and then check your app and make sure that you updated all the classes and native parts.
Checkbox checked image issue 9 years 8 months ago #11453
  • helpLineBV
I've tried some more things:
- The check mark shows correctly on a LG Nexus 5 with android version 6.0.1
- The check mark shows correctly on a Samsung Galaxy note 10.1 with android version 4.4.2
- The check mark shows correctly on a Samsung Galaxy S7 with android version 6.0.1 with Radaee version 3.5
- The check mark shows incorrectly on a Samsung Galaxy S7 with android version 6.0.1 with Radaee version 3.9
Do you know what could be wrong?
Checkbox checked image issue 9 years 8 months ago #11454
we have sent the issue to our developers.
We'll get back to you as soon as possible..
