Highlighter and other features showing error. 8 years 11 months ago #11867
  • rachnasagar
When I am using highlighter ,underline,strikeout,squiggly..Its shows some error line "add annotation failed" .
I bought the license still its showing error,
In your app RDPDF READER the same file is working fine.
Highlighter and other features showing error. 8 years 11 months ago #11870
Make sure that the professional license is activated correctly (No watermark is visible)
How are you using them, same as demo project?
Highlighter and other features showing error. 8 years 11 months ago #11872
  • rachnasagar
yea I am using in my project and no watermark is visible there but sometime it works in some of pdf's and some time it shows error.
If you like tell me the procedure to check the license is activated or not ?
Last edit: by rachnasagar.
Highlighter and other features showing error. 8 years 11 months ago #11876
can you please send us the pdf that doesn't work?
To verify if the license is correctly activated or not, you have to check if Global.Init returns true.
Highlighter and other features showing error. 8 years 11 months ago #11878
  • rachnasagar
yes I am getting the value TRUE " ms_init"
This is my pdf it is not working and many other pdf's which are not working . it shows only " add annotation failed!"
rachnasagar.in/resource/eBook/CBSE/1/Tog...ithAccountancy12.zip
Highlighter and other features showing error. 8 years 11 months ago #11881
we have checked your pdf and it doesn't have any text, it is composed by images and you can't highlight a text that is into an image.
