VPageCache.init ArrayIndexOutOfBoundsException 9 years 4 months ago #12008
  • spurgeon
  • spurgeon's Avatar Topic Author
Thanks, will do. Can you post a link where I can download 3.11 when it's released tomorrow?
VPageCache.init ArrayIndexOutOfBoundsException 9 years 4 months ago #12009
Sure, we'll respond to this post with the download link
VPageCache.init ArrayIndexOutOfBoundsException 9 years 4 months ago #12013
VPageCache.init ArrayIndexOutOfBoundsException 9 years 4 months ago #12024
  • spurgeon
Thanks for posting the link. I'll try to get this integrated and report back if I find any more crash reports. It looks like 3.11 uses API 23. Is this the minimum API for ViewLib now?
VPageCache.init ArrayIndexOutOfBoundsException 9 years 4 months ago #12025
No, it's not the minimum. You can decrease it if you want.
VPageCache.init ArrayIndexOutOfBoundsException 9 years 4 months ago #12156
  • spurgeon
We published our app with 3.11 and are getting similar crash reports. Again, these are just crash reports, so we don't have sample files, for example, that produce these crashes. Is there any insight you can provide?
java.lang.ArrayIndexOutOfBoundsException: length=0; index=-1
at com.radaee.view.VPageCache.blk_draw(VPageCache.java:254)
at com.radaee.view.VPage.vDrawStep1(VPage.java:475)
at com.radaee.view.PDFLayout.vDrawNormal(PDFLayout.java:202)
at com.radaee.view.PDFLayout.vDraw(PDFLayout.java:255)
at com.radaee.reader.PDFLayoutView.onDraw(PDFLayoutView.java:626)
at android.view.View.draw(View.java:16199)
at android.view.View.updateDisplayListIfDirty(View.java:15196)
at android.view.ViewGroup.recreateChildDisplayList(ViewGroup.java:3596)
at android.view.ViewGroup.dispatchGetDisplayList(ViewGroup.java:3576)
at android.view.View.updateDisplayListIfDirty(View.java:15156)
at android.view.ThreadedRenderer.updateViewTreeDisplayList(ThreadedRenderer.java:281)
at android.view.ThreadedRenderer.updateRootDisplayList(ThreadedRenderer.java:287)
at android.view.ThreadedRenderer.draw(ThreadedRenderer.java:322)
at android.view.ViewRootImpl.draw(ViewRootImpl.java:2627)
at android.view.ViewRootImpl.performDraw(ViewRootImpl.java:2446)
at android.view.ViewRootImpl.performTraversals(ViewRootImpl.java:2079)
at android.view.ViewRootImpl.doTraversal(ViewRootImpl.java:1119)
at android.view.ViewRootImpl$TraversalRunnable.run(ViewRootImpl.java:6060)
at android.view.Choreographer$CallbackRecord.run(Choreographer.java:858)
at android.view.Choreographer.doCallbacks(Choreographer.java:670)
at android.view.Choreographer.doFrame(Choreographer.java:606)
at android.view.Choreographer$FrameDisplayEventReceiver.run(Choreographer.java:844)
at android.os.Handler.handleCallback(Handler.java:746)
at android.os.Handler.dispatchMessage(Handler.java:95)
at android.os.Looper.loop(Looper.java:148)
at android.app.ActivityThread.main(ActivityThread.java:5443)
at java.lang.reflect.Method.invoke(Native Method)
at com.android.internal.os.ZygoteInit$MethodAndArgsCaller.run(ZygoteInit.java:728)
at com.android.internal.os.ZygoteInit.main(ZygoteInit.java:618)
at android.view.View.draw(View.java:17476)
at android.view.View.updateDisplayListIfDirty(View.java:16469)
at android.view.View.draw(View.java:17245)
at android.view.ViewGroup.drawChild(ViewGroup.java:3921)
at android.view.ViewGroup.dispatchDraw(ViewGroup.java:3711)
at android.view.View.updateDisplayListIfDirty(View.java:16464)
at android.view.View.draw(View.java:17479)
at com.android.internal.policy.PhoneWindow$DecorView.draw(PhoneWindow.java:3190)
at android.view.ThreadedRenderer.updateViewTreeDisplayList(ThreadedRenderer.java:325)
at android.view.ThreadedRenderer.updateRootDisplayList(ThreadedRenderer.java:331)
at android.view.ThreadedRenderer.draw(ThreadedRenderer.java:366)
at android.view.ViewRootImpl.draw(ViewRootImpl.java:3184)
at android.view.ViewRootImpl.performDraw(ViewRootImpl.java:2983)
at android.view.ViewRootImpl.performTraversals(ViewRootImpl.java:2572)
at android.view.ViewRootImpl.doTraversal(ViewRootImpl.java:1487)
at android.view.ViewRootImpl$TraversalRunnable.run(ViewRootImpl.java:7450)
at android.view.Choreographer$CallbackRecord.run(Choreographer.java:920)
at android.view.Choreographer.doCallbacks(Choreographer.java:695)
at android.view.Choreographer.doFrame(Choreographer.java:631)
at android.view.Choreographer$FrameDisplayEventReceiver.run(Choreographer.java:906)
at android.os.Handler.handleCallback(Handler.java:739)
at android.os.Looper.loop(Looper.java:158)
at android.app.ActivityThread.main(ActivityThread.java:7229)
at com.android.internal.os.ZygoteInit$MethodAndArgsCaller.run(ZygoteInit.java:1230)
at com.android.internal.os.ZygoteInit.main(ZygoteInit.java:1120)
