How to show content and on click of chapter ? 9 years 3 weeks ago #12048
  • rachnasagar
I want to show content from any page in pdf also on click of pdf content it will open that chapter ?
How to show content and on click of chapter ? 9 years 3 weeks ago #12052
Can you please explain with details, may be with a sample pdf?
How to show content and on click of chapter ? 9 years 3 weeks ago #12053
  • rachnasagar
I want to go to content page easily from any page of the pdf ?
I want to use the simple solution for it?
when I will click on content page it show all the chapters, I want to click on chapter(at content page) and go to that page of chapter?
How to show content and on click of chapter ? 9 years 3 weeks ago #12054
if your pdf has a table of content, the library handles it, I suggest you to check the methods under btn_outline PDFViewController.
If you want to add an internal link annotation that jumps to another page, I suggest you to use this method :
AddAnnotGoto(float[] rect, int pageno, float top)
For more info check this : www.radaeepdf.com/documentation/javadocs...o-float:A-int-float-
How to show content and on click of chapter ? 9 years 3 weeks ago #12057
  • rachnasagar
I didn't get it, Can you please explain in brief?
Also I want that It will work in all the pdf,but I think it will be fix ?
Can you please define me for any example?
And I didn't get the method under btn_outline PDFViewController.
Last edit: by rachnasagar. Reason: update
How to show content and on click of chapter ? 9 years 3 weeks ago #12058
can you please send us a pdf and a mockup with images that explains the behavior you want?
