about OnPDFBlankTapped 8 years 10 months ago #12824
  • manwon
  • manwon's Avatar Topic Author
I am testing the search bar. I press the next or previous button for searching. When I pressed those button, sometime will call the OnPDFBlankTapped. But I don't touch any blank place. How can I fix it?
Thank
about OnPDFBlankTapped 8 years 10 months ago #12825
can you reproduce it with the last demo project?
When the OnPDFBlankTapped is called, does the top bar disappear?
If yes, this means that you tapped outside the "next-previous" button area and the behavior is correct.
You can enlarge this area by adding padding or margin to the next-prev buttons in bar_find.xml
Before doing any test clean your project.
about OnPDFBlankTapped 8 years 10 months ago #12826
  • manwon
Thanks for your replay. I resolved this issue.
I have another question about searching.
I just search some text. I pressed the close button to disable search toolbar and function. But I can see the searching result.
I want to disable searching result after press the close button
See the below image link
http://imgur.com/a/lbro7
about OnPDFBlankTapped 8 years 10 months ago #12827
next time, you should split this question into another post.
To hide results you simply have to call :
m_view.PDFFindEnd();
about OnPDFBlankTapped 8 years 10 months ago #12828
  • manwon
I cannot find the PDFFIndEnd function.
about OnPDFBlankTapped 8 years 10 months ago #12829
you will find it in PDFLayoutView
