Add bitmap to certain position 8 years 9 months ago #13056
open from assets and OpenMem() are read only, so you can't modify any part of the pdf.
Try to open the pdf in other way, all will work properly.
Add bitmap to certain position 8 years 9 months ago #13057
  • msanchezv
  • msanchezv's Avatar Topic Author
Yes, it's correct!. How could I forget that assets are read-only? Thank you and everything works perfectly.
