Write PdfAcroForm 8 years 3 months ago #13753
  • app2U
  • app2U's Avatar Topic Author
I have some troubles when I trying to write a pdf AcroForm. I can write checkBox and radio Buttons and save it successfully, but I can't write the Text imputs. Nothing is showing when I write this inputs, but when I us the same pdf in the demo It works corrrectly. I don't know what I'm doing wrong, could you help me? This is my code:
Global.Init(getActivity());
Intent intent = new Intent();
intent.setClass(getActivity(), PDFViewAct.class);
intent.putExtra("PDFPath", path);
//pdfIntent.putExtra("canBePrinted", true);
startActivity(intent);
I also tried :
RadaeePDFManager pdfManager = new RadaeePDFManager();
pdfManager.show(getContext(),path,"" ,true,false,0,"RGB_565","User")
Thank you.
Write PdfAcroForm 8 years 3 months ago #13758
to edit text box you need a premium license as written here www.radaeepdf.com/documentation/javadocs...xt-java.lang.String-
the demo project is activated with a premium version, so it works properly.
So if you want to check the premium license in your own project you can follow this article : www.radaeepdf.com/support/knowledge-base?view=kb&kbartid=4
Write PdfAcroForm 8 years 3 months ago #13760
  • app2U
Yes we have a premium license
Write PdfAcroForm 8 years 3 months ago #13761
the code you sent us is about the opening, we need to know how you set the edit text..
Can you please send us that code?
Write PdfAcroForm 8 years 3 months ago #13762
  • app2U
We don't create the pdf Acroform, we open it and fill the text inputs of a Acroform that already exist so I don't set the edit text. I attached an example of pdf acroform
Thank you
Write PdfAcroForm 8 years 3 months ago #13763
there is no attachment. Can you please reupload it?
It might be a font problem, please check if you have all the fonts embedded in your pdf.
If you are missing some fonts, you can add them following that article : www.radaeepdf.com/support/knowledge-base?view=kb&kbartid=5
You can also try to change the annot font in Global class, please check setAnnotFont method.
