Roman numerals as page numbers 8 years 1 week ago #13995
we double checked the new beta version with the pdf file provided by you, and this code in viewWillAppear method:
NSString *pagenumber = [m_doc pageLabel:0];
NSLog(@"%@", pagenumber);
returns {"r":1}
Please try to remove the app from your device and reinstall using the latest beta version
Roman numerals as page numbers 8 years 1 week ago #14001
  • cornelius
  • cornelius's Avatar Topic Author
Thank you
I deleted the app and re-tested it. The page numbers do work on the sample PDF I provided, but it doesn't work on the other PDFs.
I tried a few PDFs and all of them return nil except the sample PDF I provided
Roman numerals as page numbers 8 years 1 week ago #14004
can you please provide a pdf file with the issue?
Roman numerals as page numbers 8 years 5 days ago #14011
  • cornelius
Hi
You can use the PDF in you sample app. I can replicate this with the help.pdf file
Roman numerals as page numbers 8 years 5 days ago #14012
pageLabel method follows the PDF reference 1.7 (section 8.3.1), but help.pdf version is 1.5.
Older versions probably don't follow the same references and, in this cases, you have to use Advanced APIs to get the page label.
