LongPressed Event doesn't fired 6 years 4 months ago #14511
  • tommaso
  • tommaso's Avatar Topic Author
i've a problem with " OnPDFLongPressed(float x, float y) " event from Interface ILayoutView.PDFLayoutListener it seems doesn't work.
All other inteface's event works fine but longpress no, maybe there is a parameter or method to enable it.
Have any ideas or hint's
Thanks in advance
Tommaso Honorè
LongPressed Event doesn't fired 6 years 4 months ago #14512
  • luca.f
  • luca.f's Avatar
  • Thank you received: 10
Check if you're trying to intercept it in the correct implementation of the ILayoutView.PDFLayoutListener interface:
PDFViewAct or PDFGLViewAct, depending on you using CPU or OpenGL rendering mode.
Also, it's probably more handy to use the onLongPressed() callback in RadaeePDFManager, which is called anyway by both classes.
LongPressed Event doesn't fired 6 years 4 months ago #14513
  • tommaso
Sorry I don't understand...
I use com.radaee.reader.PDFGLLayoutView
PDFOpen with parameter (document, callback)
callback -> com.radaee.view.ILayoutView.PDFLayoutListener
Call back interface contains
OnPDFDoubleTapped(float x, float y)
And
First method (OnPDFDoubleTapped) works fine
second method (OnPDFLongPressed) no
PDFGLViewAct what is it for?
Thanks in advance
Tommaso Honoré
LongPressed Event doesn't fired 6 years 4 months ago #14515
  • luca.f
  • luca.f's Avatar
Dear user,
What class are you modifying?
Where are you trying to capture the longpress event?
LongPressed Event doesn't fired 6 years 4 months ago #14516
  • tommaso
I try to intercept OnPDFLongPressed event
from com.radaee.view.ILayoutView.PDFLayoutListener interface. (without modify any class)
Simply doesn't fire onpdflongpressed event even if OnPDFDoubleTapped does
LongPressed Event doesn't fired 6 years 4 months ago #14517
  • luca.f
  • luca.f's Avatar
Ok, i think i understood your issue
go in the onLongPress() method of GLView.java: it should be all commented-out if you're using the latest version.
Just add these 3 lines inside the method:
if (m_layout == null) return;
if (m_status == STA_NONE && m_listener != null)
m_listener.OnPDFLongPressed(e.getX(), e.getY());
Then the callback you're using should be enabled.
Let us know if it works for you.
The following user(s) said Thank You: tommaso
