SetMeta on Document class 6 years 6 months ago #14867
Dear user,
We've published a new version 3.53.3beta1 that contains the mentioned fix, please check.
SetMeta on Document class 6 years 5 months ago #14878
  • devit9ar
  • devit9ar's Avatar Topic Author
We installed the new package version. I'm trying to use SetMeta, but, somehow, made the app unstable.
Looks like, depending on the base64 string stream, it brokes something inside the Document class.
The app just stop working after I use the new SetMeta. That doesn't happen always, but it does happen frequently.
We didn't have any issues before the new SetMeta. Do you guys have any idea what could possibly be?
SetMeta on Document class 6 years 5 months ago #14879
May you provide the metadata string you're loading and the device architecture (Android version, CPU type, manufacturer, model).
We will investigate the same environment you are using.
SetMeta on Document class 6 years 5 months ago #14881
  • devit9ar
Here some string examples. They always change, but the length it's always something between 2000 up to 4000 characters.
It doesn't always happen. I coudn't find a pattern for the error
File Attachment:
File Name: strings.txt
File Size:13 KB
File Attachment:
File Size:13 KB
SetMeta on Document class 6 years 5 months ago #14882
We'll check them and get back to you as soon as possible.
SetMeta on Document class 6 years 5 months ago #14883
  • devit9ar
I forgot to send you some data you asked me.
Samsung Exynos Octa 7870 1,59GHz
Android version - 9
API Level - 28
Model - SM-T395
Manufacturer - Samsung
