Reading annotations not created by Radaee 5 years 10 months ago #15243
  • MaxM
  • MaxM's Avatar Topic Author
Thanks for the answer. Checked this option works. But on condition I need to open a PDF document without downloading it to the device (tablet).
I use the code to open the document:
Document.PDFStream pdfStream = pdfStream.open(((FileSource) source).getPath());
int result = document.OpenStream(pdfStream, "");
And in this version, the annotation pages are displayed as blank, white sheets located at the end of the document.
Reading annotations not created by Radaee 5 years 10 months ago #15244
dear user:
i not understand:
if you open from a file path, codes like:
doc.Open(absolutePath, "");
doc.Close();
if you open from http address, codes like:
PDFHttpStream stream = new PDFHttpStream("http://yourdomain.com/test.pdf");
doc.OpenStream(stream, "");
doc.Close();
stream.Close();
The following user(s) said Thank You: MaxM
Reading annotations not created by Radaee 5 years 10 months ago #15245
  • MaxM
Fixed the code:
int result = document.Open (((FileSource) source) .getPath (), "");
where getPath () = "/data/user/0/by.mrsoft.mrdoc/files/Documents Files / document_be7d7e24-eaca-4c49-879f-11324f5c65ce / file_6fc35ef3-3fbb-4b8e-a352-b215b2f7b8f2"
The result has not changed. Any other suggestions.
Reading annotations not created by Radaee 5 years 10 months ago #15246
Dear user:
if this path is sand box of another app, you have no access right to open it.
if this path is located in sandbox of PDF reader, please check this path is not a directory and is a valid PDF file.
example path: "/sdcard/mydir/demo.pdf".
the path shall reference to a pdf file, and is readable by your app.
Reading annotations not created by Radaee 5 years 10 months ago #15247
  • MaxM
This is not another application, this is the application where the Radaee library is installed, and this path is not a directory. Also, this file is pdf, only without the extension.
The file is opened and read, like everyone else, the problem is that pages with annotations cannot be read (just white sheets)
Reading annotations not created by Radaee 5 years 10 months ago #15248
Dear user,
Does this happen with certain pdf or all of them?
Can you please share the pdf with us? (if the pdf is reserved you can share it on tickets area www.radaeepdf.com/support/tickets)
