SignField error 5 years 8 months ago #15294
  • devit9ar
  • devit9ar's Avatar Topic Author
Sorry for the late reply. I had other issues to solve and I wasn't able to come back to this problem.
I updated my RadaeeLib version and still have the same problems.
I'm using the following code to sign the Signature Field.
Document.DocForm form = CommonUtil.createImageForm(documento, signature, annotWidth, annotHeight);
File downloads = Environment.getExternalStoragePublicDirectory(Environment.DIRECTORY_DOWNLOADS);
String certificado = downloads.getAbsolutePath() + "/file.p12";
m_annot.SignField(form, certificado, "123456", "ITGreen", "", "", "");
'signature' is a bitmap gerenated from a Wacom service that we use for capture signatures in our project.
I think the problem might be with 'createImageForm'. I'm not sure.
What do you think?
SignField error 5 years 8 months ago #15295
i have resolved this issue by modify method CommonUtil.createImageForm().
the old codes like:
content.Create();
content.GSSave();
//draw contents on PageContent object
content.GSRestore();
new codes:
content.Create();
content.GSSave();
content.GSSave();
yes, wrap one more save/restore of graphic state can resolve this issue.
i guess this may be remain issue for Acrobat, that draw image on signed field need wrap 2 save/restore operations.
SignField error 5 years 8 months ago #15342
  • devit9ar
Sorry for the late reply. The code snippet you provided worked perfectly. That solved the problem.
Thanks!
