Adding Text using Android 11 4 years 2 months ago #15742
  • marksdl
  • marksdl's Avatar Topic Author
I am trying to run the sample app (and also integrate) the library but I am finding the text boxes on Android 11 devices you can't enter text and they disappear completely when you have finished editing. Is there a fix for this?
Adding Text using Android 11 4 years 2 months ago #15743
dear user:
this depends on font setting of annotation.
in method Global.Init();
there is code line:
        if (//!setAnnotFont("DroidSansFallback") &&
            !setAnnotFont("Arimo") && face_name != null) {
            setAnnotFont(face_name);
plz check the font exists in your project, and type only latin for "Arimo".
if you want support other language, plz set annotation font to other font.
Adding Text using Android 11 4 years 2 months ago #15744
  • marksdl
Thanks, further investigation it appears this call:boolean success = page.AddAnnotEditbox(rect, 0xFFFF0000, vpage.ToPDFSize(3), 0, 12, 0xFFFF0000);is returning FALSE - so the edit box isn't being added. Because it is a native call there isn't any error showing in the log, do you know why this might error?
Adding Text using Android 11 4 years 2 months ago #15745
1. plz confirm a premium license actived for your app.
2. PDF file is editable. Document.CanSave() shall return true.
3. setAnnotFont() invoked succeeded.
4. page object has rendered, or the page object invoked Page.ObjsStart().
Adding Text using Android 11 4 years 2 months ago #15746
  • marksdl
1. I have a Professional licence activated (does it need to be Premium instead? Professional features list text annotation)
2. Yes editable (line and polygons work for instance)
3. I iwll check
4. I will check
Adding Text using Android 11 4 years 2 months ago #15747
this is not text annotation. this called "Free Text" annotation.
the text annotation is an icon, which will popup texts when you click on icon.
text annotation is called "Sticky Text" or note annotation.
