Locking annotation added to PDF documents 8 years 3 weeks ago #13780
1. It mostly depends on your implementation flow, but the idea is to set
annot.ReadOnly = true;
when you want (after annotation creation for example).
Then check the readonly mode before the action you want to prevent, i.e. to prevent moving you can modify OnAnnotTouchMove, OnAnnotTouchEnd as follows:
if (m_status != PDFV_STATUS.STA_ANNOT) return false;
if (m_annot.ReadOnly)
    vAnnotEnd();
    return false;
2. We cannot understand the problem, can you please better explain?
Locking annotation added to PDF documents 8 years 3 weeks ago #13784
1. It can be immediately after the annotation creation:
page.AddAnnotTextNote()
PDFAnnot annot = page.GetAnnot(page.AnnotCount - 1);
and/OR it can be done on the document level for all the annotations:
m_doc = new PDFDoc();
            m_doc.Open(m_stream, "");
            for(int i = 0; i < m_doc.PageCount; i++)
                PDFPage page = m_doc.GetPage(i);
                page.ObjsStart();
                for(int j = 0; j < page.AnnotCount; j++)
                    PDFAnnot annot = page.GetAnnot(j);
                page.Close();
            m_doc.Save();
2. In the demo project this is handled via the annot open/perform button (first button on the left in the EditAnnotControl), check the video www.dropbox.com/s/e83n7c7l4zc4wu4/Note.zip?dl=0
Locking annotation added to PDF documents 8 years 3 weeks ago #13789
1. We have tested it with the demo project and no problem found, are you sure that annot.ReadOnly is false after this operation?
2. To jump the button click part, you can add the following to OnPDFAnnotClicked in PDFReaderPage:
                    mFormComboControl.Show();
                else if (annot.IsPopup && annot.Type == 1) // add type check as it enters also for highlight annot
                    //popup dialog to show text and subject.
                    //nuri is text content.
                    //subj is subject string.
                    OnPDFAnnotPopup(annot, annot.PopupSubject, annot.PopupText);
                    m_view.vAnnotEnd();
                    return;
Locking annotation added to PDF documents 8 years 2 weeks ago #13797
You need to implement both the part that sets the read-only attribute and the part that checks it
//setting the all the annotation as read only
for (int i = 0; i < m_doc.PageCount; i++)
page.ObjsStart();
for (int j = 0; j < page.AnnotCount; j++)
page.Close();
m_doc.Save();
And modify OnAnnotTouchMove, OnAnnotTouchEnd as follows:
    vAnnotEnd();
    return false;
You can download a sample from own.mobiles.it/index.php/s/LMkneRpyhCthTBc (password = Radaee)
Locking annotation added to PDF documents 8 years 2 weeks ago #13805
The demo we've sent is based on the latest stable release, so we do not think that updating these files will create an issue.
Make sure to update also the lib part (RDPDFLib bin and lib).
For the part related to the TextNote, is the part mentioned in www.radaeepdf.com/forum/Application-adop...s?limitstart=0#13789
add the following to OnPDFAnnotClicked in PDFReaderPage.cs:
                    m_view.vAnnotEnd();
                    return;
Locking annotation added to PDF documents 6 years 11 months ago #14428
  • mobileapps@dewa.gov.ae
  • mobileapps@dewa.gov.ae's Avatar
Hi
How the same thing is achieve in IOS? can you guide me?
