Android PDF lib not working on some tablets 12 years 4 days ago #6739
try these codes add to activity which PDF pages displayed:
public void onAttachedToWindow() {
super.onAttachedToWindow();
getWindow().setFormat(PixelFormat.RGBA_8888);
public void onCreate(Bundle savedInstanceState)
super.onCreate(savedInstanceState);
WindowManager.LayoutParams lp = new WindowManager.LayoutParams();
lp.copyFrom(getWindow().getAttributes());
lp.format = PixelFormat.RGBA_8888;
getWindow().setAttributes(lp);
Global.Init( this );
Android PDF lib not working on some tablets 12 years 4 days ago #6740
and SDK can only works under ARGB_8888 Bitmap object.
maybe the Bitmap object is not ARGB_8888, even you pass Config.ARGB_8888.
Android PDF lib not working on some tablets 12 years 4 days ago #6741
  • ffvanderlaan2
  • ffvanderlaan2's Avatar Topic Author
I added your code, did not help.
You might be right, but how can I check this? targetBitmap.getConfig() prints ARGB_8888. The device has Android 4.2.2
Last edit: by Rignanese.
Android PDF lib not working on some tablets 12 years 4 days ago #6742
plz test temporary library as link:
www.radaee.com/libs.rar
this library shall print logs like:
"JNI" "Need ANDROID_BITMAP_FORMAT_RGBA_8888, Bitmap Fotmat:ANDROID_BITMAP_FORMAT_RGB_565"
i'm waiting...
Android PDF lib not working on some tablets 12 years 4 days ago #6743
  • ffvanderlaan2
I already removed your code again, without it it prints:
D/JNI(7312): Need ANDROID_BITMAP_FORMAT_RGBA_8888, Bitmap Fotmat:ANDROID_BITMAP_FORMAT_NONE
Android PDF lib not working on some tablets 12 years 4 days ago #6744
OK, i'll modify codes, and test it again.
