Submit your requests and polls about new features
DIB render to bitmap RGB_565 11 years 4 months ago #8657
For both issues, please check the latest beta version www.radaeepdf.com/download/download-preview-beta.
But you need to update both libs and java classes...for tests you can test your pdfs with the demo project itself not yours, to be able to check if the issues are fixed or not.
DIB render to bitmap RGB_565 11 years 4 months ago #8658
  • caste1969
  • caste1969's Avatar Topic Author
Hi, thanks for your quickly response,
Second issue seems to be fixed.(line white color).
First issue is yet present, See the attached image for understand.
Another point is the raster of this pdf (advertise.pdf) is very slow.
Last edit: by caste1969.
DIB render to bitmap RGB_565 11 years 4 months ago #8691
Can you please attache the pdf as i cannot find it, and share the code you are using to render it.
