Features' requests: Xamarin.forms and Cordova 9 years 5 months ago #11790
  • Marat Faskhiev
  • Marat Faskhiev's Avatar
Here you can find an updated version of Cordova plugin.
I'd like to note that android version doesn't work well right after plugin install. I received the following errors during compilation:
1. Error:(64, 56) error: package R does not exist at PDFPagerAct.java
2 Error:(11, 25) error: cannot find symbol class R at RadaeePDFManager.java
Features' requests: Xamarin.forms and Cordova 9 years 5 months ago #11791
It seems like you did not execute the command
cordova build android
This command is responsible for executing configure-android.js that should fix this import error
Features' requests: Xamarin.forms and Cordova 9 years 5 months ago #11793
  • Marat Faskhiev
I checked build log. It was invoked. I see the following messages in logs:
1> Resolving module name for fs => fs
1> Resolving module name for path => path
1> Resolving module name for q => q
1> *****************************************
1> * inject file R ANDROID *
1> * Inject: io.cordova.myappff69c5.R *
1> * Inject in file: C:\Work\SampleCordovaApp\platforms\android\src\com\radaee\pdf\Global.java the import statemet: com.radaee.viewlib.R *
1> * Inject in file: C:\Work\SampleCordovaApp\platforms\android\src\com\radaee\reader\PDFCurlViewAct.java the import statemet: com.radaee.viewlib.R *
MSBUILD : cordova-build error : * missing file: C:\Work\SampleCordovaApp\platforms\android\src\com\radaee\reader\PDFCurlViewAct.java
1> * missing file: C:\Work\SampleCordovaApp\platforms\android\src\com\radaee\reader\PDFCurlViewAct.java
1> * Inject in file: C:\Work\SampleCordovaApp\platforms\android\src\com\radaee\reader\PDFLayoutView.java the import statemet: com.radaee.viewlib.R *
1> * Inject in file: C:\Work\SampleCordovaApp\platforms\android\src\com\radaee\reader\PDFNavAct.java the import statemet: com.radaee.viewlib.R *
1> * Inject in file: C:\Work\SampleCordovaApp\platforms\android\src\com\radaee\reader\PDFViewAct.java the import statemet: com.radaee.viewlib.R *
1> * Inject in file: C:\Work\SampleCordovaApp\platforms\android\src\com\radaee\reader\PDFViewController.java the import statemet: com.radaee.viewlib.R *
1> * Inject in file: C:\Work\SampleCordovaApp\platforms\android\src\com\radaee\reader\PDFPagerAct.java the import statemet: com.radaee.viewlib.R+ *
1> * Inject in file: C:\Work\SampleCordovaApp\platforms\android\src\com\radaee\util\OutlineListAdt.java the import statemet: com.radaee.viewlib.R *
1> * Inject in file: C:\Work\SampleCordovaApp\platforms\android\src\com\radaee\util\PDFGridItem.java the import statemet: com.radaee.viewlib.R *
1> * Inject in file: C:\Work\SampleCordovaApp\platforms\android\src\com\radaee\util\PopupEditAct.java the import statemet: com.radaee.viewlib.R *
1> * Inject in file: C:\Work\SampleCordovaApp\platforms\android\src\com\radaee\util\CommonUtil.java the import statemet: com.radaee.viewlib.R *
1> * Inject in file: C:\Work\SampleCordovaApp\platforms\android\src\com\radaee\util\RadaeePDFManager.java the import statemet: com.radaee.viewlib.R *
Features' requests: Xamarin.forms and Cordova 9 years 5 months ago #11794
  • Marat Faskhiev
This issue occurs because PDFPagerAct.java and RadaeePDFManager.java doesn't contains import statement which must be replaced by configure-android.js hook:
import com.radaee.viewlib.R;
And RadaeePDFManager.java contains com.radaee.reader.R instead of com.radaee.viewlib.R.
Last edit: by Marat Faskhiev.
Features' requests: Xamarin.forms and Cordova 9 years 5 months ago #11795
Thanks for the feedback, we have fixed that.
