Xamarin iOS build problem 6 years 10 months ago #14495
  • youbel
  • youbel's Avatar Topic Author
I got some problem with the library binding project for Xamarin iOS, i downloaded the github project for testing and developpement, it used to work fine but now it won't anymore.
the error i got is undefined symbols for architecture arm64 RDUPassWord
Anyone had this error before ?
thanks
Xamarin iOS build problem 6 years 10 months ago #14502
Hi youbel,
I've just tried to download the project from GitHub and replicate your move and all seems works fine.
Could you please share in which code part you have this compile error?
Xamarin iOS build problem 6 years 10 months ago #14506
  • youbel
Hello frederico
Thanks for your reply.
actually the code i want to run is the sample code from the github project, just trying to open a pdf file but it won't work.
Here is my build output.
Xamarin iOS build problem 6 years 10 months ago #14509
Hi Yubel,
We've just updated a new lib version on GitHub. Now it supports x86_64 architecture too and will solve your issue.
Xamarin iOS build problem 6 years 10 months ago #14510
Hi youbel,
Last edit: by federico.
Xamarin iOS build problem 6 years 10 months ago #14525
  • youbel
Still having the same problem.
i have the same configuration as the sample github project.
