Copied text missing spaces - v2.9.7 12 years 5 months ago #5402
  • rhill
  • rhill's Avatar Topic Author
Hi I am currently using the iOS library v2.9.7. When I select the entire page content, there are instances where some words are all stuck together and are missing the spaces that appeared to be present in the PDF itself.
I am using the following code to select the entire page content:
    PDFPage *currentPage = [m_doc page:pageNumber];
    [currentPage objsStart];
    NSString *pageString = [currentPage objsString:0 :[currentPage objsCount]];
In the one instance, the text was returned as:
Results: Of eleven studies included, six were randomised controlled
trials, three were controlled clinical trials, and two were cohort studies.
Thedischargeplanningstrategiesusedvariedwidely,mostwerelimited
to preparation of discharge during in-patient treatment. Pooled risk
I would have attached a screenshot of the PDF showing the above region but the "Add File" option is not working...
Any ideas?
Last edit: by Raj123. Reason: 2nd attempt to add PDF
Copied text missing spaces - v2.9.7 12 years 4 months ago #5505
can you try file upload with a different browser?
Copied text missing spaces - v2.9.7 12 years 4 months ago #5549
  • rhill
added PNG showing PDF file that caused resulted in the text being retrieved not having any spaces...
Copied text missing spaces - v2.9.7 12 years 4 months ago #5555
  • stronglee
  • stronglee's Avatar
  • Thank you received: 2
could you upload this pdf file let me check this problem.
Copied text missing spaces - v2.9.7 12 years 4 months ago #5559
  • rhill
having real trouble attaching files :(
Copied text missing spaces - v2.9.7 12 years 4 months ago #5560
  • rhill
Having to send the PDF to your support email address as there is absolutely no way I can get it to attach here in the forum...
