View is not opening 12 years 3 months ago #6034
  • stronglee
  • stronglee's Avatar
  • Thank you received: 2
Did you find RDPDFReflowViewController? and push it like below:
RDPDFReflowViewController *m_pdfR;
m_pdfR = [[RDPDFReflowViewController alloc] initWithNibName:@"RDPDFReflowViewController" bundle:nil];
[m_pdfR PDFOpen:pdfFullPath];
UINavigationController *nav = self.navigationController;
m_pdfR.hidesBottomBarWhenPushed = YES;
[nav pushViewController:m_pdfR animated:YES];
View is not opening 12 years 3 months ago #6042
  • stronglee
#import "RDPDFReflowViewController.h"
in your viewController ,and push it as follow
View is not opening 12 years 3 months ago #6046
  • imran.nazeer
  • imran.nazeer's Avatar Topic Author
*nav returns null..
View is not opening 12 years 3 months ago #6047
  • stronglee
That means your viewcontroller didn't
has a navcontroller.You should add a navcontroller
,you can read the source code in demo project.
navController is define in RDAppDelegate.
RDFileTableController is first ViewController,
in RDFileTableController.m line 449
#pragma mark - Table view delegate
- (void)tableView:(UITableView *)tableView didSelectRowAtIndexPath:(NSIndexPath *)indexPath
this method show how push another viewController.
Last edit: by GoliNeneswees.
View is not opening 12 years 3 months ago #6048
  • stronglee
If in your project you don't want use navigatorBar . For example : One ViewController jump to another,
ViewControllerB =[ [ViewControllerB alloc] initWithNibName :xxxxx bundle :nil];
[self presentViewController:ViewControllerB: animated:YES completion:nil]; //self in current ViewController
