Text selection on ipad Retina 64bit 11 years 5 months ago #8581
  • Elaine
  • Elaine's Avatar Topic Author
Text selection on the retina devices are not working as expected, text is not highlighted after long press . Is there a solution for this?
Text selection on ipad Retina 64bit 11 years 4 months ago #8599
text selection only works on licensed version.
demo project actived a premium license by default, are u using demo project?
if u changed package name from demo, text selection shall not working.
Text selection on ipad Retina 64bit 11 years 4 months ago #8609
  • Elaine
We currently have an active premium license. But as soon as i select text it does not display on the screen? Any ideas?
Text selection on ipad Retina 64bit 11 years 4 months ago #8612
do u means any PDF file can't select text, and can select on 32 bits platform?
Text selection on ipad Retina 64bit 11 years 4 months ago #8614
  • Elaine
Yes on the 32 bit devices selection is working fine, it is just the retina devices.
Text selection on ipad Retina 64bit 11 years 4 months ago #8615
  • stronglee
  • stronglee's Avatar
  • Thank you received: 2
Hi,this bug fixed ,new version will updated as soon as quickly.
