How to get index while storing a text annotation? 10 years 10 months ago #9558
  • tanvi
  • tanvi's Avatar Topic Author
Need to retrieve the index value that RadaeePDF internally stores. Please let me know the sequence in which the methods are invoked inorder to store a text annotation.
How to get index while storing a text annotation? 10 years 10 months ago #9561
you should take a look at vAddTextAnnot method (PDFView class)
The following user(s) said Thank You: tanvi
How to get index while storing a text annotation? 10 years 10 months ago #9633
  • tanvi
Hi Emanuele,
I have tried retrieving the index value for PDFAnnot's but was unable to get the correct index value since it was returning different values everytime you open the same PDF.
Also, the index value for the 1st note created was not always 0. For some PDF files it started with 15, as the annotCount returned was 16.
How to get index while storing a text annotation? 10 years 10 months ago #9635
I tried to reproduce this issue, but I get always the same index for the same annotation.
What kind of annotation are you using?
Can you share the pdf used for this test?
How to get index while storing a text annotation? 10 years 10 months ago #9639
  • tanvi
Annotation is type of note (m_status = sta_note).
The PDF is "help.pdf" used in your demo project for iOS.
Will it make a difference if we have completely disabled the scrolling of PDFView?
How to get index while storing a text annotation? 10 years 10 months ago #9640
may you send us one of your annotated file?
may be put here your code snippet you're using to
- create annotation
- retrive annotations
One more question: are you removing annotations from page?
Last edit: by support.
